Because the Evaluated Value isn't matching my Value / Text Expression, the title block on my drawings are showing the incorrect information...
Hey Wayne,
All of the configuration specific properties show the correct value between the value/text expression and the evaluated value, but when I click on "this configuration" (no matter which configuration I'm on), the material and finish evaluated values are incorrect. If that makes sense?
I'm using SLDWKS 2020, but the caveat is the original models were made in SLDWKS 2016 and have been saved in SLDWKS 2020. I think that might explain why we're getting a strange "linked to parent" type error where a custom property continues to show up.
Zach
Is the configuration you are applying the values for the active configuration? What version of SOLIDWORKS are you running?
