I am trying to update my sheet size to D but I am not seeing any of the options in the Standard sheet size location.. Is there someway I can download these or...
You can Browse to this location below which contains default templates of various sizes:
C:\ProgramData\SOLIDWORKS\SOLIDWORKS 2019\lang\english
Depending on which year Solidworks you are using, please browse to the correct year version
Hi Ryan,
What standard did you choose when installing Solidworks?
If you make a new drawing go to options > document properties tab: (mine is set to ISO)
If it is not ANSI , then you have found the cause.
Eddy
Uncheck the 'Only show standard format' box just above the circled window and the rest should appear.
