This drives me nuts. Why is it so difficult to select items behind transparent surfaces / solids? I have "Select Through Transparency" enabled yet it seems to only work half the time and only with certain tools.
i.e. It doesn't work with the Measure tool.
Hi Dave,
I never use "select through transparency" because it never felt consistent to me.
There is another way of selecting faces, which you can always use to select faces behind others "Select other". I will show how it works using some screenshots on a U shaped part:(I show the click location with a red cross)
When you RMB on a face and use "Select other", Solidworks makes a ray(line of infinite length from where you click normal to the screen.) and collects all the faces it pierces.
In my example we get the following popup, which makes it possible to select 3 faces (where the ray goes through).
In a simple case like this you can select the one you want.
But if there are much more faces there is another way of doing things: you can RMB on every face in the graphics area you don't want. In the screenshot below I clicked twice with RMB and that makes all the faces invisible except the one on the back. Remark the pointer with the mouse image(the eye says when you RMB it will change visibility)
Eddy
