I have a Solidworks file with about 700 configurations in it of a reasonably complex part (so hand calculations are out of the questions). There is a single body resulting from all the different features and operations in the function tree.
I would like to compute the surface area for all 700 configurations and output this to a .txt file, as in 'Configuration = XX' where the number is the computed surface area.
That script should also spot any transient error in the configuration change (every now and then, I get a rebuild error which disappear when I force a rebuild by opening and closing the equations).
I will most likely have to let the PC run the macro overnight, since each configuration change takes on average 30s.
Has anyone come across anything similar?
TIA!
S.M.
Hello. Try this:
