Hello everyone, I have a simple question, can anyone help me out to create "crease of 4 degree" on a sheet metal part?
I have a rectangle sheet metal part with a drain hole at the bottom, I cannot use cross break option as this drain hole is not at the center of the part but its way more towards the left of the part and this 4 Degree crease helps the water to travel towards the drain.
Thank you.
I believe your best option for this would be to create a forming tool. This could not be created with a standard sheet metal bending process. I would have to be stamped or created in multiple pieces.
