Hi all.
Is there a best practice for you guys who have used SW for a while to be able to make sure that the ability to view for each of the parts is separated? I'm having this issue with the wings that I've been working on and for some reason when I'm trying to view just the surface or just the ribs and I tried to hide either the surface of the ribs, they both disappeared. Here's an example. I'm going to hide the surface I circled in red below.
As you can see, as soon as I hide the views on the surface, the ribs also disappear.
Is there a best practice or a way to do the separation so that I can choose the piece I want to hide and work on? Please advise?
Your model has only two bodies, one solid body and one surface body.
You can't hide features, only bodies. Delete (or suppress) the Combine feature and edit the Surface cut so that it cuts the LinearPattern1. Then your wing body and rib body will be separate:
