Hi, i'm quite new here on the forum, however already about 20 yrs of experience with Solidworks, almost 30 yrs with 3D CAD. At his moment I'm struggling with some Drawing Template issues. Due to the fact that the Standard SW property "SW-BOM Part Number(BOM Part Number)" is not showing what I would and should expect started to work with macro's. The problem is as follows: I have an assembly on sheet 1, all of my components on separate sheets in the same drawing. That's just to save part number info on mono drawings because we will never have these underlaying parts in the warehouse, only in the finished assembly. In my template, for the title i'm now looking at the property "SW-Sheet Name(Sheet Name)". Therefore I have to rename my sheets. Sofar I was able to get all the things working as it should, On-save, On-change, On-open, the macro runs automatically. Made a Listener event, can start the listener automatically via the start option /m.
Now, when I his morning SW, opened a Drawing, the renaming does it's work however, not completely. So I'm searching where it goes wrong. Following code, made by myself and used some of the on the internet avalable examples.
Set Model = swApp.ActiveDoc
Set Part = swApp.ActiveDoc
Set swDraw = Model
vSheetName = swDraw.GetSheetNames
FilePath = Part.GetPathName
Newsheetname = Mid(FilePath, InStrRev(FilePath, "\ST") + 1, 8)
For i = 0 To UBound(vSheetName)
swDraw.ActivateSheet vSheetName(i)
Set myDrawingSheet = swDraw.GetCurrentSheet
If i = 0 Then
myDrawingSheet.SetName Newsheetname
ElseIf i > 8 Then
myDrawingSheet.SetName "#TEMP" & Newsheetname & "-" & i
Else
myDrawingSheet.SetName "#TEMP" & Newsheetname & "-0" & i
Next i
myDrawingSheet.SetName Replace(vSheetName(i), "#TEMP", "")
Next i
swDraw.ActivateSheet vSheetName(0)
Anyone why SW doesn't perform the last "replace" correct?
Hi Dick,
Welcome to the Solidworks forum !
I had a look at your code and it works for me as expected except some minor remarks:(marked in code)
How many sheets do you have? I tested on 13.
I suspect this code is just for testing/debugging.
Did you set a breakpoint on the line you mention? This can help to pinpoint the problem you are having.
Set swDraw = Model
Newsheetname = Mid(FilePath, InStrRev(FilePath, "\ST") + 1, 8) 'REMARK:gives the path without filename
If i = 0 Then
ElseIf i > 8 Then 'REMARK Change 8 to 9
Else
Next i
Next i
Hope it helps,
Eddy
