custom blank shape (manually defined flat pattern)
Question asked by Tim Rosendal Halvorsen on Dec 7, 2020
Latest reply on Dec 7, 2020 by Heiko Sohnholz
Hi all
I have a part created in sheet metal, but the actual flat pattern should be different.
imagine having a plate with a lot of machining, but you also need to have the stock material laser cut.
So, attached simple part have the default config, which is the one I need to machine.
The Flat Pattern configuration is the stock I need to order.
Reason I want this to be a true flat pattern is because I use CUSTOMTOOLS to create the DXF files from parts where configuration is flat pattern.
So I can't have multiple configurations - it should act like a normal sheet metal part, and when I flatten it, the block shape would be displayed.
Also, the thickness is different as you will notice, and it is the thickness of the block I need.
Let me know if this can be done !
File is made using SW2020
