I use the following code to try to control "Color Display Mode"
BoolStatus = swModel.Extension.RunCommand(swCommands_e.swCommands_ColorDisplayMode, "")
The code does successfully change the "Color Display Mode", but it toggles the state. With now way of know what the state is before running the command, I don't know if I will be enabling or disabling the mode.
Is there a way to read the state of this mode in VBA?
Thank You.
Hi Mark,
did you try the solution in this post:
https://forum.solidworks.com/thread/66221#350698
Eddy
