I am trying to mesh a part that was supplied by a vendor. The part is a multi body part with some of the bodies interfering. Most of the interference is from threaded parts. I have removed as many interfering bodies from the part as I can. However, there are a couple of bodies that I would like to keep and the interfere. I have attached a photo showing the interference.
The question, what is the best way to fix this interference so that I can mesh the part?
Also, I am trying to do a thermal simulation.
Paul
Try combine them to remove interference.
You might also need to do some extrude to combine or remove interference.
