Manipulating the parameters to fit certain objective and constrains
Yes we can.
In Solidworks, if you cut a simple hole in a plate, SHIFT+drag -> MOVE, CTRL+drag -> COPY.
Everything looks wondeful when you do thing just to show.
But I'm an engineer and I have to design for manufacture, not for show, and when I start to put dimensions on features, the part needs to be solid and steady and make sure nothing starts floating around.
Hi Afia,
Yes we can.
Use Instant3D and set your sketch visible. Then you can drag the centerpoints or the circle itself.
Eddy
