Good afternoon ,having an isue with PDM task. For a start i want to change a sheet format in a transition. This is ok you create TASK, right click button it works, however if its integrated into workflow it sets all my variables, then check in, then starts a task to change sheet format - and then nothing happens.
What does the task list look like for it when it is triggered by workflow, does it hang on processing?
Does it work if there are no Set Variable actions for the transition? I suspect that issue is with setting variables requiring a check out and check in and your task does a check out to change sheet format and check in. If it does work without any Set Variables, try moving the task in the actions to run it first.
