I have a weldment that has a plate that I need to make a separate drawing for. I saved the body out into a new part. The issue is the tapped holes will not call out in the drawing. I get the tap drill diameter not the thread call out. Just wondering if there is a way around this besides manually typing the information in.
You don't need to create a new part. In the drawing, when creating a new view, you can select the body to put on the view.
