This plane is at a point which 100mm dimension from the Top plane. In the later stage of modeling part, I want to have 100mm dimension instead of the point. Is it possible to replace it? Because if it is a dimension plane can be moved up and down not with the point.
You can notice this post is two times. First time post appeared with moderation notification, therefore I deleted it and repeat the post again, second time it appeared without moderation notification.
This is my approved first post.
only if I dig to find your specific posts, which I do not do. I just skip the recents when I get on here.
if you don't want duplicate posts, don't post duplicate posts, or delete one.
