I quickly threw together a macro to help fix some of our older parts manually:
It deletes all cfg specific properties and adds our standard properties to the configuration specific tab. Since this is my first macro I'd like someone with more experience to look over it & tell me if I need to adjust something in it or not - or if I can delete obsolete code.
I attached a test file too.
Here is the code:
Option Explicit
Set swModel = swApp.ActiveDoc
'delete all configuration specific properties in all configurations
Dim vConf As Variant
For Each vConf In swModel.GetConfigurationNames
ClearCustPrps CStr(vConf)
Next
'populate all configurations with their respective configuration specific properties
PopulatePrps CStr(vConf)
Next
MsgBox "Configuration specific properties deleted and repopulated!"
'delete cfg specific properties
Sub ClearCustPrps(conf As String)
Dim swCustPropMgr As SldWorks.CustomPropertyManager
Dim vPropNames As Variant
Dim vPropName As Variant
Set swCustPropMgr = swModel.Extension.CustomPropertyManager(conf)
If Not swCustPropMgr Is Nothing Then
swCustPropMgr.GetAll vPropNames, Empty, Empty
If Not IsEmpty(vPropNames) Then
For Each vPropName In vPropNames
swCustPropMgr.Delete vPropName
Debug.Print vPropName
Next
Sub PopulatePrps(ConfigName As String)
Dim i As Long
Dim PrtName As String
Dim SetVal As Long
Dim CusPropMgr As SldWorks.CustomPropertyManager
Set CusPropMgr = swModel.Extension.CustomPropertyManager(ConfigName)
'Values & custom property names
Dim prpWeight As String
Dim prpMatGrade As String
Dim prpMatShape As String
Dim prpMatSize As String
Dim prpCutLength As String
Dim prpCost As String
Dim ValWeight As String
Dim ValMatGrade As String
Dim ValMatShape As String
Dim ValMatSize As String
Dim ValCutLength As String
Dim ValCost As String
Dim CusPrpArray(0 To 5, 0 To 1) As String
'get part name
PrtName = swModel.GetTitle
'set standard values for properties
prpWeight = "Weight"
prpMatGrade = "Material Grade"
prpMatShape = "Material Shape"
prpMatSize = "Material Size"
prpCutLength = "CutLength"
prpCost = "Cost"
ValWeight = """SW-Mass@@" & ConfigName & "@" & PrtName & """"
ValMatGrade = """SW-Material@@" & ConfigName & "@" & PrtName & """"
ValMatShape = "Plate"
ValMatSize = """Thickness@@" & ConfigName & "@" & PrtName & """"
ValCutLength = """Length@Sketch1@@" & ConfigName & "@" & PrtName & """"
ValCost = """SW-Cost-TotalCost@@" & ConfigName & "@" & PrtName & """"
'fill array with standard values'
CusPrpArray(0, 0) = prpWeight
CusPrpArray(1, 0) = prpMatGrade
CusPrpArray(2, 0) = prpMatShape
CusPrpArray(3, 0) = prpMatSize
CusPrpArray(4, 0) = prpCutLength
CusPrpArray(5, 0) = prpCutLength
CusPrpArray(0, 1) = ValWeight
CusPrpArray(1, 1) = ValMatGrade
CusPrpArray(2, 1) = ValMatShape
CusPrpArray(3, 1) = ValMatSize
CusPrpArray(4, 1) = ValCutLength
CusPrpArray(5, 1) = ValCost
'add values to custom properties
For i = 0 To 5
SetVal = CusPropMgr.Add3(CusPrpArray(i, 0), swCustomInfoType_e.swCustomInfoText, CusPrpArray(i, 1), swCustomPropertyAddOption_e.swCustomPropertyDeleteAndAdd)
Next i
Next I want to add to copy everything from one of the configuration specific tabs (probably the active configuration) to the custom property tab. Any code I 'steal' from/modify easily to achieve this?
I found this already.
Thank you!
