Hi All,
I tried to refresh the file or folder after I change state. But its not working. Anybody have idea to do this?
Imports EdmLib
Imports System.Runtime.InteropServices
Imports System.Windows.Forms
'Create GUI &Main Class
<Guid("A849A492-C192-4DBF-9B17-7007BE7C6782")>
<ComVisible(True)>
Public Class Rev_Up_Main
Implements IEdmAddIn5
Public Sub GetAddInInfo(ByRef poInfo As EdmAddInInfo, poVault As IEdmVault5, poCmdMgr As IEdmCmdMgr5) Implements IEdmAddIn5.GetAddInInfo
'Basic Names of an Addin
poInfo.mbsAddInName = "Revision Update"
poInfo.mbsCompany = "Test"
poInfo.mbsDescription = "PDM Rev Integration Addin"
poInfo.mlAddInVersion = 1
poInfo.mlRequiredVersionMajor = 6
poInfo.mlRequiredVersionMinor = 4
'Get Card Button's Click (Adding Hook)
poCmdMgr.AddHook(EdmCmdType.EdmCmd_CardButton) ' Card button click
poCmdMgr.AddHook(EdmCmdType.EdmCmd_PreState) ' Change State
'Addin Settings
poCmdMgr.AddCmd(1, "Test Addin")
Public Sub OnCmd(ByRef poCmd As EdmCmd, ByRef ppoData As Array) Implements IEdmAddIn5.OnCmd
Dim strVaultName As String = poCmd.mpoVault.Name
Select Case poCmd.meCmdType
Case EdmCmdType.EdmCmd_CardButton
If poCmd.mbsComment = "Rev_Up" Then
For Each AffectedFile As EdmCmdData In ppoData
Dim btnVault As IEdmVault16 = TryCast(poCmd.mpoVault, IEdmVault16)
Dim btnFile As IEdmFile5
Dim folder As IEdmFolder10 = btnVault.GetObject(EdmObjectType.EdmObject_Folder, AffectedFile.mlObjectID2)
Dim btnCurrentStateName As String = "INWORK"
Dim btnDestStateName As String = "Revision Up"
btnFile = btnVault.GetFileFromPath(AffectedFile.mbsStrData2)
Dim filePath As String = AffectedFile.mbsStrData2.ToString
Dim directoryPath As String = System.IO.Path.GetDirectoryName(filePath)
If Not btnFile.IsLocked Then
Try
btnFile.ChangeState(btnDestStateName, AffectedFile.mlObjectID2, "RevUp", 0, 0)
btnVault.RefreshFolder(directoryPath)
btnFile.refresh()
folder.Refresh()
Catch ex As Exception
MessageBox.Show(ex.Message)
End Try
Next
End Select
End Class
