Hi All,
Stumped on this one. Seems like a simple enough move but I'm getting 2 different resutls. I added a simple BOM to my assembly drawing the other day which showed the bolts correctly with the size (attachment OLD BOM). I lost the drawing for some reason so made a new drawing and everything appears the same except the hardware now shows ai_bolt instead of the actual sizes shown in the BOM (attachment NEW BOM). I don't see anything different in the options box for the BOM from what I thought I had set a few days earlier (attachment BOM OPTIONS). I did some googling and don't see anything directly pointing to this question, only something about the bolt configurations causing this but I never set anything other than the defaults previously and they always showed properly. Any help is appreciated!
Looks good to me:
I thought the second one would be set to Filename, but it's ok.
You could test if you can change things. Maybe you can force solidworks to reinitialize the settings that way.
