Hello ,first apology from me , for my English.
I will try to explain my needs as best as i can.
I really like multibody modelling , and until now i always used "save bodies" (with create assembly option) and then i created separately drawing for each derived part. SW is able to recognize same parts , and put them in more instances in assembly and that was really great for me.
Now , i want to try multiple drawing sheets , and i use select bodies to detail parts i need , but the question is what is best way to check which parts are same so i dont details two same parts? I use weldments all the time , and often i have a large number of bodies .That option in save bodies from SW to recognize same ones was great, but now i kind of need to check it by myself because i dont wanna detail two exactly same bodies.
For more clarity see picture below , those two bodies are the same and i know that so i will details just one of them , but sometimes i have 100+ bodies which can be similar (or same) so i wanna try to avoid checking if they are same by myself.
I hope you guys can understand me , any suggestions? Thanks!
The best way to find unique bodies is to get them from the cut list in the multibody part. Then SolidWorks does the checks for you.
Because making a drawing sheet for each unique body is a pain to do manually, I automated it with Drew:
https://cadbooster.com/drew
I find the unique bodies in a multibody part and create a sheet per body, including outer dimensions and a balloon and a flat pattern for sheet metal bodies. If the part changes and new bodies are added, I can add a new sheet for those new bodies.
