I found a lot of parts (gears, splines, etc) at my job have patterns that take a LONG time to rebuild because they are not set to be "Geometry Patterns". I made a macro that goes through every feature in a part and sets every pattern feature to "Geometry Pattern" It works well for Mirror, Circular, Curve Driven, Linear, Sketch Driven, Table DrivenPatterns. I cannot get it to work with Fill Patterns (APattern). The code runs fine, no errors, but the "Geometry Pattern" setting won't change (from true to false, or vice versa).
Here's a subset of the code:
Dim swFeat As SldWorks.Feature
Dim swFillPatternFeatureData As SldWorks.IFillPatternFeatureData
Set swModel = swApp.ActiveDoc
Set swFeat = swModel.FirstFeature
While Not swFeat Is Nothing
Select Case swFeat.GetTypeName
Case "APattern"
Set swFillPatternFeatureData = swFeat.GetDefinition
swFillPatternFeatureData.GeometryPattern = True
swFeat.ModifyDefinition swFillPatternFeatureData, swModel, Nothing
End Select
Set swFeat = swFeat.GetNextFeature
Wend
The other thing I have tried is changing data type "SldWorks.IFillPatternFeatureData" to "SldWorks.FillPatternFeatureData" [dropped the "I"]
I know my code is good because it works well for every other pattern time. There's clearly something fishy about fill patterns since both "FillPattern..." and "IFillPattern..." date types work.
Thank you for taking a look at this.
I've used your code on a plate with a hole from hole Wizard,
and it worked as expected.
Maybe it comes from your part. If you attach it, I could do some more tests.
