I am creating a fabrication drawing & I am using 3 files. I have custom properties for each file that I want linked to each page of the drawing. However, all of my custom properties in my drawing are linked to my first part that I inserted into the drawing...each part displays the same mass in my drawing (the mass of part 1) !! It's very frustrating.
How do I ensure that the custom properties for each page are linked to the part that is on the page????
FYI I have add new sheets by clicking "insert new" but I get the same problem. How should I overcome this problem when I add new pages/sheets for different parts?
Any input welcome, thanks!
Usually custom property values are given by the part in the main view (the first part you put in) as a default, unless the option shown below is enabled.
It is a drawing template setting. It must be changed in the drawing template.
Furthermore, if you want to get the the custom property from a part shown in another view, rather than the default view, you can do it by choosing the view in the sheet properties:
