Part in graphic area has become invisible. How to fix it? This is only problem with 2020v, no problem with 2018v & 2019v.
Try clicking on the feature and choose "Hide", then repeat and choose "Show". If that doesn't work post the Part here.
Maha Nadarasa wrote:
It does not work. Problem is not confined to particular part. This a problem with SWX 2020v.
I'm using SW2021 now, but I used several versions of SW2020 and didn't have that issue, so I don't see how you can make that statement. I believe the problem is something on your end. Again, please post a Part that's exhibiting this behavior.
This sounds like it's an issue with the display list driver. I've had something similar but not version specific. What I would have to do was to change the model to the front view & then regenerate the view. That would seem to refresh the display list. Also make sure that you have the latest driver for your video card and it is an approved card or Solidworks will tell you the issue is the video card
Maha,
Try disabling enhanced graphics performance in system options > performance (scroll to bottom).
Thanks, Kyle
Maha,
Thanks, Kyle
