I have the following part that is a doubler for a tank.
When I suppress the Cut-Extrude 2 I can get the flat pattern but if it is active it comes up with an error.
I tried few options in the cut function but nothing is working.
Does anyone have an idea?
I've taken a look at your part and founds some ...difficulties:
1.) You've used an ellipse as the profile for a base flange. SWX isn't very good using these. And it's result is NOT an radius, as a bend has usally. But I understand, that you might need this profile...
2.) With this said, SWX shows it's problems at this cut, wich isn't going through.
3.) A fixed edge for the flat pattern in the middle of the part? No, this won't work reliable in SWX.
4.) But you've rounded away all linear edges SWX could use instead...
5.) Using an approximated profile will work (together with the other changes). But is it accepable for you?
