I have a spreadsheet tracking orders for over 20 individual BOMs at various engineering revisions. I am attempting to use the Solidworks API for PDM to pull the BOMs from SLDASM files and export updates to each excel sheet.
I've gotten started writing the VBA in excel to do this, but I've run into a roadblock as it seems there are aspects of the API that are not supported in VBA, but are in VB.NET.
Is it possible to use excel VBA by itself to pull BOM data from PDM, or is it a waste of time trying to make this happen without the use of VB.NET or some other script? If it is, could someone point me to an example of how to make it work?
thank you
For that you can simply change this:
Dim vault1 As IEdmVault5 = New EdmVault5()
Dim vault As IEdmVault8 = DirectCast(vault1, IEdmVault8)
To:
Set vault1 = New EdmVault5
Set vault = vault1
There maybe some other tricks later on in the code to convert an array of objects into VBA recognized syntax.
