Multibody part:
Bend Lines in Flat State (unsupressed)
DXF/DWG Output (In Cutlist Part) does not show Bend Lines:
Maybe Someone has a solution?
This error occurs sometimes, mostly when there are more than 1 sheet metal part. But Solidwroks is designed to export these features, yet it fails.
I use Solidworks 2019 SP 5.0
Update. :
I have noticed that this error occurns when Sheet metal part is split with a SPLIT command:
Some parts have no Bend Lines when exported.
a short test in SWX2021SP1 showed up the bend lines in all 3 bodies, when exported to DXF.
SWX2020SP4 does not.
