Hello, I used Splines and extrude to make a D shape. Although it looks smooth in Solidworks, the resulting 3D print does not. I can see a series of rectangular segments making up the curved surface. This shows up when I viewed the STL file using a viewer. How to create smooth surfaces so that they not only look smooth in Solidworks but also look smooth when printed using a 3D printer? Is there a setting to create smooth curve surfaces in STL format?
STL files are triangulated surface files where it breaks surfaces into triangles. In SOLIDOWORKS you do have options to increase the number of triangles it will break the curved surfaces into.
