I'm currently fighting with a performance issue and I hope to find a way to improve that.
I'm currently working on a macro that cleans up the active sketch in a part which is imported geometry. That sketch contains 38,000 (in other cases even more) sketch segments of different types. I cannot provide an example here as it is very detailed customer data but maybe still someone has a good approach.
The selecting part is quiet easy. I filter the unwanted elements by type, length etc. and select them and that only takes a few seconds for many thousand elements.
But then when deleting the geometry this takes a long time, e.g. 12min for 26,000 elements (just lines and arcs so far).
Here is what I checked / tried to improve the performance:
- there is not even one sketch relation in that sketch
- automatic solve is disabled
- the image quality of the document is very low
- I tested both ModelDocExtension::DeleteSelection2 and ModelDoc2::EditDelete
- I've set ModelView::EnableGraphicsUpdate to false
- I've set ModelDoc2::Visible to false
- I've set SketchManager::AddToDb to true
- I've set SketchManager::DisplayWhenAdded to false
- I moved the sketch geometry out of the visible part in the graphics area
- I've rotated the view 90° so that my view is parallel to the sketch plane
- I minimized the SOLIDWORKS window
Is there anything else that could make that run faster?
Thanks in advance.
Kind regards
Ronny
Hi Ronny
This is probably a daft idea but as you are deleting the majority of the entities could you reverse the process?
ie - create a new sketch recreating just the entities you want to keep.
I dont know if this has any merit, but it was my first thought. creating 12000 entities may be quicker than deleting 26000
