Is it possible to toggle (on, off) "Enable selection through transparency" . I found some help here :2017 SOLIDWORKS API Help - System Options > Selection
but have no clue how to use it..
This works fine. I wanted to change(on or off) this property any time i use the makro and i wrote something like this:
Dim A As Integer
Dim SelTrhTrnsp As Boolean
SelTrhTrnsp = swApp.GetUserPreferenceToggle(swUserPreferenceToggle_e.swDisplayEnableSelectionThroughTransparency)
MsgBox (SelTrhTrnsp)
If SelTrhTrnsp = True Then
swApp.SetUserPreferenceToggle swUserPreferenceToggle_e.swDisplayEnableSelectionThroughTransparency, False
Else
swApp.SetUserPreferenceToggle swUserPreferenceToggle_e.swDisplayEnableSelectionThroughTransparency, True
I don't know why but macro always goes the "else" way. Even if i get in msgbox true macro don't take the "then" way but goes to "else" line. Somebody could tell me why?
swApp.SetUserPreferenceToggle swUserPreferenceToggle_e.swDisplayEnableSelectionThroughTransparency, True ‘enables, False to disable
