I have been racking my brain to find a solution to this and cant seem to find any consistent solution.
On our drawing we have a series of drawing blocks, which include 3rd angle projection, revision history and multiple more. In the drawing template I have created a "Construction" layer which is normally hidden in the layer properties and is used for all construction lines. This includes any construction lines in any blocks and the title block.
When I create the block in the drawing and toggle the layer visibility all lines on the construction layer turn on and off as expected, including within the block.
I then save the block externally to be used in the design library, and once re-inserted into the drawing the visibility of the construction layer no longer toggles with the layer properties.
Any help would be greatly appreciated.
Thanks!
Solidworks 2020, SP5
I have since been in touch with our re-seller and this is a bug consistent for them inSOLIDWORKS 2020. I have since upgraded to 2021 SP1 and I now have no issues toggling the visibility of hidden layers.
Liam
