Add offset on smart fastener
Question asked by Gustav Rydn on Nov 12, 2020
Is it possible to make the bolt offset from the surface that you select for inserting the fastener?
I cannot select the plate, only the beam in the "Selection"-box. Therefore the nut lays flat against the beam. But I want it to lay flat against the plate (which is 15 mm or 0.6 inch thick).
