JHJoon Hee Jang05/11/2020
I am having problem in changing orientation. Changes in standard view is not retained.
What I did:
In the orientation tool (Space) - update standard view - select a view
It opens a warning "Changing this standard view will change the orientation of any... Do you want to make this change?"
Select Yes
Save file and close
When I open the file again the view orientation went back to default
Is this normal? I was expecting the view setting would saved with file/template. How do I change the view for good?
Edit:
Like Alex Lachance suggested I made a dummy part. for others to try. The file is made from SW2021 SP0. I am trying to rotate the view so that the word "TOP" is read from left to right on "top view" (Ctrl +5). Please let me know if anyone can save the view. Then, I will know it is my system problem.
Update 11.10.2020
I reset my computer and reinstalled SW2021. Still having the same problem. I would like to know if anyone has the same issue.
Update 12.14.2020
I just received SW2021SP1 update and confirmed that this issue is fixed.
