TMTerje Moe04/11/2020
Hello
I’m about to install SW 2021 on a new pc without any previous SW-install. My question are: when you down load the install package, will it matter what drive you put it on or install from, does SW expect it to be from your c-drive if you are installing to the c-drive? When you run SW will it need access to the drive that you installed from or is everything needed copied to the C-drive.
Terje
