Ben Kalinowski
Search for file using Dispatch
Discussion created by Ben Kalinowski on Jun 1, 2009
I'm using a template to add a new file whose name is either based on a counter or could be user entered. If the user enters a desired filename, I want to check and see if it already exists before trying to add it. The filename is what I am interested in. The extension could be the usual suspects: sldprt, sldasm or slddrw.
I was hoping to do this w/o the user needing to select all the files in the folder, too.
I've tried the jump command and it doesn't seem to do the trick.
Any thoughts would be helpful.
