Valdas K.
Multibody Sheet Export to DXF with Cutlist Naming
Discussion created by Valdas K. on Oct 24, 2020
Latest reply on Oct 26, 2020 by Valdas K.
Hello, is there a way to export all metal sheets' flat patterns from a multibody part to separate DXFs with naming from their cultist parameters?
If part has many sheet metals,  I want to export them all with name:
Thickness, Partnumber, Material, Quantity.
example: "S-3 P001 AISI304 2Pcs"
Is it possible to make or modify a code to do that?
Example (3 different elements, but only 2 elements are sheets with flat pattern. Can they be exported to their DXF as flat patterns and include bend lines?):
Example 2 (Cultist items Sheet 1 and Sheet 2 have there marked parameters, can they be added to saved DXFs' Filenames respectively?) :
