PGPeter Gutfeldt23/10/2020
How can I insert the value of some arbitrary dimension in a model into the callout for another dimension on the drawing?
Currently I would like to do this in order to call out the depth of a slot. There's no slot depth variable so I'd like to put something like the following in the slot callout:
<hw-slot-width> X <hw-slot-length> <HOLE-DEPTH><abritrary-dimension-value>
Where <abritrary-dimension-value> inserts the value of the extrude cut feature depth from the model. I imagine there is some way to do this with a global variable?
Other instances I can recall in which I would have liked to be able to do this include adding a far side countersink line to a hole callout where the countersink was added with a revolve cut instead of with hole wizard (somebody else made the part, not me).
