So, I've copied a body using the move/copy body feature. Now I want to supress and unsuppress some features in the original body but I don't want the copied body to change. Is there any way of doing this? I believe I have to break the parent/child relation but I'm not sure if it's possible.
I know that ideally I'd just place those features down below in the feature tree, but in this particular case I can't.
The way I'm current doing it is saving a second version of the file with a different name, then I open the first version and import the copied body into it. The copied body is referencing the second version of the file so I can change the original body with no impact on the copied one. It works but it's a bit convoluted and I need a better and simple process.
