Traverse and skip components on design tree
Question asked by Nelson Caeiro on Oct 14, 2020
Latest reply on Oct 19, 2020 by Nelson Caeiro
Hi everyone,
I have modified the macro posted in Code Stack Traversing the components tree using SOLIDWORKS API in order to print the drawings of all the components inside the active assembly.
There will be instances that I have an sub-assembly as a reference only/ excluded from BOM. So I need a way to for the macro to skip all components tagged with "exclude from BOM".
Im not proficient at all on VBA. I just grab examples on the Internet and kinda merge them together. If anyone could modify the macro for me, I would greatly appreciate it.
Also, the traverse portion doesn't follow the order of the design tree; if that could be changed, it would be perfectly splendid.
Thanks!
Dim swDwg As SldWorks.ModelDoc2
Dim swExt As SldWorks.ModelDocExtension
Dim PrintSpec As SldWorks.PrintSpecification
Dim DrawingFile As String
Dim Errors As Long
Dim Warnings As Long
Const INDENT_SYMBOL As String = " "
Set swModel = swApp.ActiveDoc
If swModel.GetType = swDocumentTypes_e.swDocASSEMBLY Then
DrawingFile = Left(swModel.GetPathName, InStrRev(swModel.GetPathName, ".") - 1) & ".slddrw"
Debug.Print DrawingFile
If Dir(DrawingFile) <> "" Then
swApp.OpenDoc6 DrawingFile, swDocDRAWING, swOpenDocOptions_Silent, "", Errors, Warnings
swApp.ActivateDoc2 DrawingFile, True, longstatus
Call Print_current
swApp.CloseDoc DrawingFile
Dim swRootComp As SldWorks.Component2
Set swRootComp = swModel.ConfigurationManager.ActiveConfiguration.GetRootComponent
TraverseComponent swRootComp, ""
Else
MsgBox "Please open assembly"
Sub TraverseComponent(comp As SldWorks.Component2, indent As String)
Dim vChildComps As Variant
vChildComps = comp.GetChildren
Dim i As Integer
For i = 0 To UBound(vChildComps)
Dim swChildComp As SldWorks.Component2
Set swChildComp = vChildComps(i)
DrawingFile = Left(swChildComp.GetPathName, InStrRev(swModel.GetPathName, ".") - 1) & ".slddrw"
Call Print_current
TraverseComponent swChildComp, indent & INDENT_SYMBOL
Next
Sub Print_current()
Set swDwg = swApp.ActiveDoc
Set swExt = swDwg.Extension
Dim myPageSetup As Object
Set myPageSetup = swDwg.PageSetup
myPageSetup.DrawingColor = swPageSetupDrawingColor_e.swPageSetup_BlackAndWhite
myPageSetup.ScaleToFit = True
myPageSetup.Orientation = swPageSetupOrientation_e.swPageSetupOrient_Landscape
myPageSetup.PrinterPaperSize = 17
Set PrintSpec = swExt.GetPrintSpecification
PrintSpec.ScaleMethod = swPrintAll
'swExt.PrintOut4 "", "", PrintSpec
Debug.Print "----------" & swDwg.GetPathName
Set swExt = Nothing
Set swPrintSpec = Nothing
Set swDwg = Nothing
