I am in a very small assembly. One fixture plate with two parts mounted to it. I am programming a CNC machine and need to select all the faces you see in this vertical finger shaped notch so I can cut all the faces at once. Window select is the obvious way to do it. Even with the face filter on, the window select does nothing. if I start the window outside the model and bring it in, at least I get a window to appear but it does not collect anything when I let up on the mouse button. It all works fine if I try it in just a model (not an assembly). It is crazy for me to have to select all these faces one by one. Hopefully this is not my only option. Thanks.
Jody does the selection count with fillet and chamfer! when you select the face?
