REVISON table change column properties
Question asked by Grega Kalan on Oct 8, 2020
Latest reply on Oct 17, 2020 by Grega Kalan
I would like to correct the drawings which have an older version of the revision table.
In column 3, I would replace the column name with "Spremenil" and the Colume properties of the column to APPROVED.
The macro works for me. I just don't know how to change Column Properties to APPROVED?
Dim swApp As Object
Dim Part As Object
Dim boolstatus As Boolean
Dim currentSheet As Object
Dim myRevisionTable As Object
Dim swSheet As SldWorks.Sheet
Dim setColumnCustomProperty As Variant
Set swDraw = swApp.ActiveDoc
If Not swDraw Is Nothing Then
Set swSheet = swDraw.GetCurrentSheet
Dim swRevTable As SldWorks.RevisionTableAnnotation
Set swRevTable = swSheet.RevisionTable
If Not swRevTable Is Nothing Then
swRevTable.Text(0, 4) = "Spremenil"
'swRevTable.setColumnCustomProperty(0, 3) = "APPROVED"
Else
Set Part = swApp.ActiveDoc
Set currentSheet = Part.GetCurrentSheet()
Set myRevisionTable = currentSheet.InsertRevisionTable(True, 0.205, 0.287, 2, "D:\....\Revizija PDM.sldrevtbt")
Else
MsgBox "Please open a drawing"
