Grega Kalan
macro HELP:)  open part from drawing and fill the configuration custom properties from excel database.
Discussion created by Grega Kalan on Oct 1, 2020
Latest reply on Oct 6, 2020 by Grega Kalan
Hi I need a litle help for my macro.
1. First I want to open part from active drawing.
this is my macro that doesn't work :S
Dim swApp As Object
Dim sFileName As String
Dim Drw As Object
Set Drw = swApp.ActiveDoc
Set fso = CreateObject("Scripting.FileSystemObject")
sFileName = Left$(Drw.GetPathName, (Len(Drw.GetPathName) - 6)) & "SLDPRT"
If fso.FileExists(sFileName) Then
    Set Part = swApp.OpenDoc(sFileName, swDocPART)
    Else: MsgBox ("Part does not exist")
2. I want to fill configuration costume properties from exel detabase.
I would like the macro  find in Excel the corresponding properties (Description, PART NUMBER ...) according to the file name (name of part). However, they must be entered at the configuration level (cofiguration specific).
like:
$PRPSHEET:{Description} for Description
This is the code that works for me. but I don't know how I need to fix it to make it work at the configuration level
Dim excApp As Excel.Application
Dim swCustPrpMgr As config.CustomPropertyManager
Dim PARTNUMBER As Object
Set excApp = GetObject(, "Excel.Application")
Set swModel = swApp.ActiveDoc
Set swCustPrpMgr = swModel.Extension.CustomPropertyManager("")
Dim excRange As range
Dim excSheet As Excel.Worksheet
Set excSheet = excApp.ActiveSheet
Set excRange = excSheet.range(excApp.Cells(1, 1), excApp.Cells(1000, 1))
Dim searchRes As range
Dim name As String
Dim index As Integer
Dim title As String
title = swModel.GetTitle()
index = InStr(title, ".")
name = Left(title, Len(title) - IIf(index = 0, 0, index + 1))
Set searchRes = excRange.Cells.Find(name)
If Not searchRes Is Nothing Then
LinkPrpToCell searchRes.row, 1, "Item No"
LinkPrpToCell searchRes.row, 2, "PART NUMBER"
LinkPrpToCell searchRes.row, 3, "Description"
LinkPrpToCell searchRes.row, 4, "SAP Number"
Sub LinkPrpToCell(row As Integer, col As Integer, prpName As String)
Dim value As String
Dim field As String
field = prpName
value = excApp.Cells(row, col).value
swCustPrpMgr.Add2 field, swCustomInfoType_e.swCustomInfoText, value
swCustPrpMgr.Set field, value
Excel, test parts, macro..... everything is attached in "macro.rar"
Some code is based on already written macros from Deepak Gupta. I hope he doesn't mind.
thanks
