Having a issue transferring from PCB to Solidworks, Can someone help?
Question asked by Lee Havens on Sep 30, 2020
Latest reply on Oct 2, 2020 by Andrii KOLOMIIETS
Hello all,
       So just some background information, This board was imported from pads as ascii and txt files. This gave me both the board and schematics. I this was able to extract all the libraries from the board. The issue I am having is that the board only need a few footprints adjusted and traces slide do to the shrink in size. Everything seemed fine till I went to use the connector to send it to Mechanical. The exact error is "Board outline has self-intersection at point ( x-33449 , y-36000 )". Which also makes no sense because the board is only 3800 x 7500. I have gone to the supposed point and cant find any artifacts or anything to select. Also not that all footprints were double checked to make sure it had nothing to do with issue. So my question is how do I fix this? I tried everything I could think of, any suggestions would certainly be welcomed.
               Thank you for your time,
                Lee
