Can I "
LINK" dimensions from two different parts in an assembly?
I want the lenght of part 1 to be equal to the length of part 2, and be able to update that dimension in either of the parts.
I would like to do it with Linked dimensions and not convert entites or add relations. Can I use a link or an equation?
It works something like this:
Part A has configurations that are each 1" 2" and 3" long.
Part B also has configurations that are 1" 2" and 3" long.
Assembly C, which consists of Parts A and B, has configurations which are 1" 2" and 3". For example, the 1" configuration of the assembly will use the 1" configuration of Parts A and B.
I don't know if its the simplest method, but its what I use. I would also be interesteed to see how others approach this.
Josh
