I have a 3DSketch that I want to identify whether it is hidden or visible in each drawing view. Using ITreeControlItem, I successfully get the sketches I am interested in, but when I cast as a feature, IFeature::Visible returns the value at the model, not in the drawing view.
For clarification, I am not trying to use IModelDoc2::.SetUserPreferenceToggle (swUserPreferenceToggle_e.swDisplaySketches, bool) because the sketches are set to hidden in the model, and I need them temporarily in the drawing view for a convert entities scenario.
Here's what I have so far. I assume I need something after "Private Sub SetVisVal" at line 74. I just don't know what command identifies the visibility state of a TreeControlItem.
How do I return the visibility of the sketch at the drawing view, and not the model within the drawing view?
Dim swModel As ModelDoc2
Dim vViews As Variant
Dim swDraw As DrawingDoc
Dim swView As View
Dim feat As Feature
Dim featMgr As FeatureManager
Dim swSheet As Sheet
Dim focusFeat As Feature
Dim visible As swVisibilityState_e
Dim swSketch As sketch
Dim selMgr As SelectionMgr
Dim rootNode As TreeControlItem
Dim sheetNode As TreeControlItem
Dim sheetFeat As Feature
Dim viewNode As TreeControlItem
Dim viewFeat As Feature
Dim modelNode As TreeControlItem
Dim featNode As TreeControlItem
Dim subFeatNode As TreeControlItem
Set swModel = swApp.ActiveDoc
Set swDraw = swModel
Set selMgr = swModel.SelectionManager
visible = swVisibilityStateUnknown
Set featMgr = swModel.FeatureManager
Set rootNode = featMgr.GetFeatureTreeRootItem2(swFeatMgrPane_e.swFeatMgrPaneTop)
While Not rootNode Is Nothing
Set sheetNode = rootNode.GetFirstChild
While Not sheetNode Is Nothing
Set sheetFeat = sheetNode.Object
'Debug.Print sheetFeat.name & " - " & sheetFeat.GetTypeName2
If sheetFeat.GetTypeName2 = "DrSheet" Then
Set viewNode = sheetNode.GetFirstChild
While Not viewNode Is Nothing
Set viewFeat = viewNode.Object
'Debug.Print viewFeat.name & " - " & viewFeat.GetTypeName2
If viewFeat.GetTypeName2 = "AbsoluteView" Or viewFeat.GetTypeName2 = "UnfoldedView" Then
Set modelNode = viewNode.GetFirstChild
If Not modelNode Is Nothing Then
Set featNode = modelNode.GetFirstChild
While Not featNode Is Nothing
Set feat = featNode.Object
'Debug.Print feat.name & " - " & feat.GetTypeName2
If feat.name = "SkRoute1" Then
'found
SetVisVal featNode
Else
Set subFeatNode = featNode.GetFirstChild
If Not subFeatNode Is Nothing Then
Set feat = subFeatNode.Object
If Not feat Is Nothing Then
'found
SetVisVal subFeatNode
Set featNode = featNode.GetNext
Wend
Set viewNode = viewNode.GetNext
Wend
Set sheetNode = sheetNode.GetNext
Wend
Set rootNode = rootNode.GetNext
Wend
Debug.Assert Null
Private Sub SetVisVal(thisNode As TreeControlItem)
Dim thisFeat As Feature
Set thisFeat = thisNode.Object
Debug.Print thisNode.Text
If visible = swVisibilityStateUnknown Then
visible = thisFeat.visible
thisFeat.Select2 False, -1
Select Case visible
Case 1 'hidden
swModel.UnblankSketch
Case 2 'shown
swModel.BlankSketch
End Select
I have also tried the following code, with the same results:
