Valdas K.
Write Thickness to Configuration Specific Macro
Discussion created by Valdas K. on Sep 26, 2020
Latest reply on Sep 27, 2020 by Valdas K.
I have a code, which should write to each configuration a parameter = thickness.
Storis = Thickness
But the "Thickness" comes as word - text. I want it to be as parameter of sheet thickness.
I know that the culprit is this line:
swModel.CustomInfo2(swConfig.Name, "Storis") = "Thickness"
if I write Thickness without "" - it is a variable, but I don't know how to make that variable connected to sheet thickness.
The code here:
Option Explicit
Dim vConfNameArr As Variant
Dim i As Long
Dim swConfig As SldWorks.Configuration
'config manager
Dim swConfigMgr As SldWorks.ConfigurationManager
Set swModel = swApp.ActiveDoc
vConfNameArr = swModel.GetConfigurationNames
'config manager
Set swConfigMgr = swModel.ConfigurationManager
Set swConfig = swConfigMgr.ActiveConfiguration
For i = 0 To UBound(vConfNameArr)
Set swConfig = swModel.GetConfigurationByName(vConfNameArr(i))
'Add "Storis" = SW-Thickness - thickness of sheet
Next i
