How do I add a blank row to a revision table with a macro WITHOUT incrementing the rev?
Question asked by Jim Warren on Sep 24, 2020
Latest reply on Sep 28, 2020 by Jim Warren
Hello SW friends! I need a macro that adds a simple row to the top of my (bottom-up) rev table, but doesn't increment the revision. Here is the code I borrowed and modified:
Dim swApp As Object
Dim swSheet As SldWorks.Sheet
Set swDraw = swApp.ActiveDoc
If Not swDraw Is Nothing Then
Set swSheet = swDraw.GetCurrentSheet
Dim swRevTable As SldWorks.RevisionTableAnnotation
Set swRevTable = swSheet.RevisionTable
If Not swRevTable Is Nothing Then
AddRevision swRevTable, " ", Array("", "", "RELEASED TO PRODUCTION")
Else
MsgBox "There is no revision table in the drawing"
Else
MsgBox "Please open a drawing"
Sub AddRevision(swRevTable As SldWorks.RevisionTableAnnotation, revName As String, rowData As Variant)
Dim i As Integer
Dim swTableAnn As SldWorks.TableAnnotation
Set swTableAnn = swRevTable
swRevTable.AddRevision revName
For i = 0 To UBound(rowData)
If rowData(i) <> "" Then
swTableAnn.Text(swTableAnn.RowCount - (swTableAnn.RowCount), i) = rowData(i)
Next
This code gives me the row, which includes today's date, and the "RELEASED TO PRODUCTION" description. Unfortunately, it also increments the revision, so that the next revision skips a letter (since this rev is blank).
Is there a way to do this?
without the next revision being Rev E?
If I manually add a row (LMB top row - insert: row above), then type in the info, the rev stays correct, like this:
Any help would be appreciated. I am hoping to use this code to automate production release of multiple drawings.
Thanks a ton,
                    Jim
