Michael Dunne
Print Assembly Drawings in Order they apear in design tree.
Discussion created by Michael Dunne on Sep 22, 2020
New to SW API
Currently running SW 2019 SP5 in a non PDM enviroment
I am trying to find a way to modify this macro I found so that it only would print the assembly drawings from the model and not any of the part drawings
Code is as follows
Dim swApp                   As SldWorks.SldWorks
Dim swModel                As SldWorks.ModelDoc2
Dim swFeat                  As SldWorks.Feature
Dim swComp               As SldWorks.Component2
Dim strstrDwgPath      As String
Dim CurrentDoc          As SldWorks.ModelDoc2
Dim swDrawToPrint    As SldWorks.ModelDoc2
Dim CurrentDocQuit   As SldWorks.ModelDoc2
    Set swModel = swApp.ActiveDoc
    Set swFeat = swModel.FirstFeature
    While Not swFeat Is Nothing
        If swFeat.GetTypeName2 = "Reference" Then
            Set swComp = swFeat.GetSpecificFeature2
            If UCase(Right(swComp.GetPathName, 3)) = "ASM" Then strDwgPath = Replace(UCase(swComp.GetPathName), "SLDASM", "SLDDRW")
            'If UCase(Right(swComp.GetPathName, 3)) = "PRT" Then strDwgPath = Replace(UCase(swComp.GetPathName), "SLDPRT", "SLDDRW")
            Set swDrawToPrint = swApp.OpenDoc6(strDwgPath, swDocDRAWING, swOpenDocOptions_Silent, "", Empty, Empty)
            If Not swDrawToPrint Is Nothing Then
                swApp.ActivateDoc swDrawToPrint.GetPathName
                Set swPageSetup = swDrawToPrint.PageSetup
                swPageSetup.ScaleToFit = True
                swPageSetup.PrinterPaperSize = 1
                Debug.Print swDrawToPrint.GetPathName
            Else
            swApp.QuitDoc swDrawToPrint.GetTitle
        Set swFeat = swFeat.GetNextFeature
    Wend
I tried to comment out
If UCase(Right(swComp.GetPathName, 3)) = "PRT" Then strDwgPath = Replace(UCase(swComp.GetPathName), "SLDASM", "SLDPRT")
then it would output multiple instances of the assembly drawing preceeding any sldprt features
and if i try to print by replacing Debug.Print swDrawToPrint.GetPathName with
CurrentDoc.PrintDirect
I receive
Run Time error '91':
Object variable or With block variable not set
