Artem Taturevych
Export All Flat Patterns from SOLIDWORKS assembly components
Discussion created by Artem Taturevych on Sep 21, 2020
In this YouTube video I demonstrate how to use a macro to export flat patterns from all components within the assembly. One of the main benefits of the macro is the ability to use placeholders in the path template for the output files. You can use cut-list properties, file name, configuration, and feature name as a placeholder for file path (name and sub-folders). So it is for example possible to specify the path to group outputs by thickness.
Artem
