Kyle Blough
Changing macro to write to config specific prop
Discussion created by Kyle Blough on Sep 16, 2020
Latest reply on Sep 17, 2020 by Kyle Blough
Hi folks,
I am not well versed in API/Macro, and I need some help converting a macro I found from codestack to write to a configuration specific property.
Macro can be found here: Macro to copy SOLIDWORKS custom property from material to model
The specific section I am having difficulty is follows:
Sub SetCustomProperty(model As SldWorks.ModelDoc2, prpName As String, prpVal As String)
    Dim swPrpMgr As SldWorks.CustomPropertyManager
    Set swPrpMgr = model.Extension.CustomPropertyManager("")
    swPrpMgr.Add3 prpName, swCustomInfoType_e.swCustomInfoText, prpVal, swCustomPropertyAddOption_e.swCustomPropertyReplaceValue
    swPrpMgr.Set2 prpName, prpVal
It works perfect to write to global properties, but I need this to write to configuration specific properties since I use configurations heavily.  I tried changing out CustomPropertyManager to ConfigurationManager, that did not do it.  I tired to set swPrpMgr to swConfigPrpMgr and other instances, but that did not do it either.
So, my entry level api experience has come to ahead, and I need help.
Kyle
