AHAndrew Harkins15/09/2020
Hello all,
I have a C# program winform/WPF and I can successfully log into my vault. I can get all of my files in the whole vault in my listview. Now I want to put only the files in a certain directory. My vault is setup like so:
Vault1 -> (multiple county folder names) US, DE, IN, Global -> PDF, Docx, DXF.
I would like only the files in the path Vault1->US->PDF
When I try to edit IEdmFolder5.LocalPath to the correct directory it will not cuz its ‘Read-Only’
I am new with this API so I don’t fully understand what each number behind the type of object means.
IEdmVault5 vault5 = new EdmVault5();;
private void btnLogin_Click(object sender, RoutedEventArgs e)
            try
                if (!vault5.IsLoggedIn)
                    vault5.Login("loginName", "loginPass", "Vault1");
                TraverseGlobalVault(vault5.RootFolder);
            catch (Exception ex)
                MessageBox.Show(ex.Message);
private void TraverseGlobalVault(IEdmFolder5 folder)
            string lvlTwo = "PDF";
            string lvlOne = "Global";
            try
                //folder.LocalPath = @"C:\\Vault1\" + lvlOne + "\" + lvlTwo;
                //enumerate the files in the folder
                IEdmPos5 filePos = default(IEdmPos5);
                filePos = folder.GetFirstFilePosition();
                IEdmFile5 file = default(IEdmFile5);
                while (!filePos.IsNull)
                    file = folder.GetNextFile(filePos);
                    lstFiles.Items.Add(file.Name);
                //Enumerate the sub-folders
                IEdmPos5 folderPos = default(IEdmPos5);
                folderPos = folder.GetFirstSubFolderPosition();
                while (!folderPos.IsNull)
                    // MessageBox.Show(folderPos.ToString());
                    //IEdmFolder5 folder5 = (IEdmFolder5) folderPos;
                    MessageBox.Show(folder.LocalPath);
                    //if (folderPos.Equals(@"C:\\Vault1\" + lvlOne + @"\" + lvlTwo))
                    //    IEdmFolder5 subFolder = default(IEdmFolder5);
                    //    subFolder = folder.GetNextSubFolder(folderPos);
                    //    TraverseVault(subFolder);
