How to rename all bodies to follow doc name + extention?
Question asked by Albert Koffeman on Sep 15, 2020
Hello, I'm trying to make a macro to rename all bodies in a part to have the document's name + extention.
For example: the part's name is 50001234, now I want the bodies to be named 50001234-01, 50001234-02 etc.
So here is what I have until now:
Option Explicit
Dim swModel As ModelDoc2
Dim swFeat As Feature
Dim swBodyFol As BodyFolder
Dim vBodyArr As Variant
Set swModel = swApp.ActiveDoc
swModel.ClearSelection2 True
Set swFeat = swModel.FirstFeature
Do While Not swFeat Is Nothing
If swFeat.GetTypeName = "SolidBodyFolder" Then
Set swBodyFol = swFeat.GetSpecificFeature2
vBodyArr = swBodyFol.GetBodies
RenameBodies swModel, vBodyArr
Exit Do
Set swFeat = swFeat.GetNextFeature
Loop
Sub RenameBodies(swModel As SldWorks.ModelDoc2, vBodyArr As Variant)
Dim vBody As Variant
Dim swBody As Body2
Dim prefixName As String
Dim bodycount As Integer
bodycount = 1
If IsEmpty(vBodyArr) Then Exit Sub
prefixName = "doc_name"
For Each vBody In vBodyArr
vBody.Name = prefixName & bodycount
bodycount = bodycount + 1
Next vBody
swModel.EditRebuild3
So the body names are now doc_name1, doc_name2 etc. instead of actually following the part's name
I know where the crutch is, but I don't know how to fix it.
Can anyone help out? What do I have to change to get it to work?
Thanks in advance, kind regards,
Albert Koffeman
