Hi , I am new to macro. i just want to create a macro for generating a circle in which diameter of circle will be taken from file property. Please help me out.
Thanks in advance!
Thanks in advance!
Hi Deepak,
When you say generate a circle, can you not just create this using a property within the equations?
Hi Nathan,
We can definitely create. circle is just an example, the real scenario is that i have many solid bodies in a part file which contain many features apart from circle and all these things are being created using a macro. I want to link dimensions used in these features to custom properties. This is because , once i run the macro and get my model created and i want to change dimensional parameters of any feature, just go to custom file property and change the value rather than going to sketch and changing the value.
Hi Deepak,
What code do you have so far?
Eddy
